#1 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: yaris Y 2010 A.K.A. "sky" Join Date: Jul 2010
Ciao !!! Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter) Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way |
#2 | |
#3 | |
#4 | |
Form>Function
That is odd that you are rubbing on that set up. On 8" wide wheel, +20 on 195s I barely rubbed. I was pm 15s but my fender gap is non existant so I should be rubbing a lot more than you if you're rubbing already. I did have the same thing you describe where only my rear driver tire rubbed which was caused by the seating postion combined with the lower spring rate in the rear. Try rolling/pulling the fenders |
#5 | |
#6 | |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 03:23 PM |
| Want to lower 1" or so. hmmm | piranha0522 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 03-25-2011 03:59 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-10-2009 10:12 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | General Yaris / Vitz Discussion | 5 | 12-10-2009 06:49 PM |
| Lower Grill Replacement Idea (feeler) | counterfiend | Cosmetic Modifications (Exterior/Interior) | 7 | 09-24-2009 08:40 PM |
