Old 09-04-2012, 02:40 AM   #20
Originally Posted by xtremist View Post
i got the same tire as you want (205/40/17). mine is Nitto tires (Japan). I got a problem because my G-games wheel has +40 offset, the rear tires are rubbing on the fender when Im fully loaded even in a small uneven surface...Im planning to change my wheels sooner or later
Rubbing with +40 offset? Only time I started rubbing was when I had 17x7.5, ET28 with 205/40/17 tires. Rolled the rear fenders, and rubbing went away. Now I'm on 17x8, ET32 in the back, and no rubbing.
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Want to lower 1" or so. hmmm piranha0522 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-25-2011 03:59 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 08:40 PM
