What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
So I need to install this thing on the manifold
http://www.amazon.com/Parker-2-4-B2H...d_sbs_indust_3 and move that oil pressure thing I have on there now to another thing?
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
やりすぎだ~
EDIT: DISREGARD THIS POST.
No, I don't think CTScott is telling you to switch those two. I think your oil pressure thing that you have in there is fine where it is. As for the skinny hose that's coming out of your live unit, that has to tap into your intake manifold. This way your live unit will detect how much boost you're getting and inform you when you look at your boost gauge. Last edited by yarisugi; 10-15-2012 at 11:05 PM. |
#3 | |
やりすぎだ~
OK my bad! Sorry Mason.
So you're saying to remove the pressure sensor and replace it with the 1/4-1/8" fitting for the vacuum line from the live unit. Where does the sensor go to? Are there other orifices? |
The pressure sensor is for oil pressure. You would mount that somewhere where you can see the oil pressure, like at the filter sandwich adapter that they mention in the instructions.
#6 | |
| Upper driver's side glove box w/ holes cut for gauges | PETERPOOP | Items for Sale by private party | 9 | 07-31-2011 07:21 PM |
| Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder | bieniman | DIY / Maintenance / Service | 4 | 05-19-2009 11:40 PM |
| My new gauges set up | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 30 | 04-19-2009 08:50 PM |
| Mechanical vs Electric Gauges? | PETERPOOP | Forced Induction Forum | 13 | 04-06-2009 01:25 AM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
