Old 10-21-2012, 08:25 PM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Shaft. So to get ignition switched I'll just have to plug into that panel under the dash and route it back through the firewall? Will it be OK to ground it to the frame or do I need to run the ground back through to there also?
Old 10-21-2012, 08:30 PM   #2
Chassis grounding is fine. You can go through the little grommet that is right above the ECM for making your way into the cabin.
Upper driver's side glove box w/ holes cut for gauges PETERPOOP Items for Sale by private party 9 07-31-2011 07:21 PM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-19-2009 11:40 PM
My new gauges set up PETERPOOP Cosmetic Modifications (Exterior/Interior) 30 04-19-2009 08:50 PM
Mechanical vs Electric Gauges? PETERPOOP Forced Induction Forum 13 04-06-2009 01:25 AM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
