![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
drilled the wrong hole, what now?
i was installing a switch today and i didnt realize there's a metal piece behind it and I couldn't put the switch it. I am now left with a hole like this. Any idea what i should do to cover it up? how much is it if I buy the whole piece?
![]() thanks |
やりすぎだ~
Ouch. That lower dash assembly is a good junkyard find part. The other option would be to cover that little section with some adhesive vinyl.
metallic green vitos
nah...if i was you i would buy a piece of plastic and fix it on it....
![]() ![]() Drives: 2012 Yaris LE Join Date: Oct 2012
![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
Finish and clean up the cut, find a switch that will fit the opening, gut it flat, (dremel it shallow so it fits)
install. Serves no purpose other than camouflage. |
#7 | |
USAF_SrA_E-4
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
The plastic jack holder under your driver's seat should be the same color. Just cut a small rectangle a little larger than your unfortunate plastic surgery malpractice error and glue it over. It shouldn't be that noticeable.
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
| What's this hole in my air intake? | Yury | General Yaris / Vitz Discussion | 22 | 01-23-2012 07:00 PM |
| Big BAD-ASS Brakes...Drilled | xbgod | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 09-15-2010 07:54 PM |
| Drill hole in Driver's glovebox? | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 07-05-2010 05:26 PM |
| Screwdriver popped a hole | behour | General Yaris / Vitz Discussion | 5 | 01-30-2010 08:05 PM |
| Spoiler installation gone wrong | jinxor | Cosmetic Modifications (Exterior/Interior) | 7 | 03-24-2009 12:13 AM |
