Hard to tell much from the video. Try hitting the exhaust with your hand or a soft mallet. See if you get any rattles. Also while cold, take your finger and pull on the manifold heat shield etc and try to "twang" it like a guitar string to get a noise. Often the best way to find loose heat shields. Just watch for sharp edges.
Other things that come to mind: -cracked exhaust -plugged cat or broken baffle in muffler causing intermittent plugging (but would expect to notice this driving, not at idle) Any other engine problems with the car? Is it stock? |
| vitz high idle problem after cleaning the throttle body. | dindy | DIY / Maintenance / Service | 20 | 11-07-2012 05:05 PM |
| chirp/squeak noise just off idle when cold | tadc | DIY / Maintenance / Service | 14 | 02-20-2011 03:09 PM |
| annoyin noise (ticking or rattling) on idle.. | abdallah380 | DIY / Maintenance / Service | 2 | 04-18-2009 05:40 PM |
| high pitch whine at 100km/h | Moore | General Yaris / Vitz Discussion | 9 | 06-11-2007 07:22 PM |
