Old 02-02-2013, 09:09 AM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
@tooter so the tb installation requires a larger o ring, possible chip swap, removal of epoxy, and adjusting the idle set screw? I skipped anything about the butterfly valve needing space since Im sure MI thought of those dimmensions with the new manifold design since they wanted to be able to combine the two for even better performance.
Old 02-02-2013, 12:41 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
You're absolutely right. A larger butterfly likely won't clear a smaller stock bore, so it's a simple matter to make a larger bore and larger diameter gasket to fit both throttle bodies.
You want the flow to be compatable with the larger throttle body anyways.
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 02:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 07:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 12:58 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 09:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-14-2008 12:26 AM
