Old 02-18-2013, 08:45 PM   #1
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
An update: a bit more tweaking and I've got this 1zz throttle body dialed in. The car drives great now, about 250 miles on the car since install. It takes about 30 seconds for the idle to climb down on cold starts and it's fine after that. I took the car out on some of my favorite roads and the new manifold/throttle body gave it a noticeable power bump, it's especially snappy coming out of tight corners in 2nd and 3rd gear while high in revs.
Overall I'm extremely happy with the upgrade! Thanks again for the advice everyone.
4/20 NEVER FORGET is offline   Reply With Quote
Old 02-18-2013, 08:54 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I'm happy for you...
The 1ZZ throttle body is one of the best bang for the buck mods you can do because it enhances all of the other mods.
Old 02-19-2013, 01:46 AM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Agreed 100%
Other than the high idle at cold starts (which I'm fine with), I have nothing to complain about. It's been running great for many years, and it did in fact make the rest of my existing performance mods shine even more.
BTW, Did you guys bypass the coolant line on your 1ZZ TBs? I did it since day one with no issues so far. Just wondering if you all did the same...
Old 02-19-2013, 02:32 PM   #4
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Agreed 100%
I bypassed the coolant line on mine, and I live in WI where temps regularly get into single digits for 4-5 months of the year. Zero problems.
Old 02-18-2013, 09:09 PM   #5
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Angry
What are you idling at?
-Type 07 FFL-
My odometer 03/11
Old 02-20-2013, 04:37 AM   #6
4/20 NEVER FORGET
Not sure, I have't installed my tach yet. It's quite low though, I had it where the engine was just starting to shake from the idle being too low, then I turned it back a bit and it's been great ever since.
I did not bypass the coolant line to the throttle body, we get freezing fog and occasional snow here so I didn't want to have to worry about it, so I kept the coolant lines running to the throttle body.
And Captain Slow, I can relate when it comes to worrying about idle issues, I've had idle issues with many cars in the past and they are one of the most annoying things to deal with. Other than the high idle on cold starts, I have absolutely no issues with the car idling now. Hopefully that will ease your mind a little, I wanted to post my issues here so I could get some help and as you can see, it got sorted out. At very least, you could swap back to the stock throttle body and fix any idle issues that may have came from the throttle body swap. From what I gather from the system, the idle is completely controlled by the throttle body, there isn't any bypass valves or seperate sensors on the manitfold that dictate the idle other than the throttle body. So if you were having issues, it'd be an easy fix.
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
