Old 02-20-2013, 06:29 AM   #1
I am not sure what the dealer would charge, but replacing the belt is actually a very easy DIY. You loosen the upper and lower alternator bolts, move the alternator towards the engine block to remove it, slip the new one on in its place, hold tension on the alternator, and tighten the alternator bolts.
The one thing you have to be careful of is not breaking the OCV (the small cylindrical device on the left side of the engine) when holding tension on the alternator.
Old 02-20-2013, 06:38 AM   #2
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Thanks so much.
What could that squeaking sound be when I press the clutch pedal?
Old 02-20-2013, 07:04 AM   #3
Originally Posted by junorico24 View Post
Thanks so much.
Depending on where the squeak is coming from, it can be as easy as applying a little lithium grease to the pivot point of the pedal (if it is coming from inside the car) or to the linkage for the clutch master or slave cylinder (if it is coming from under the hood).
Old 02-20-2013, 10:06 PM   #4
alanwagen
I just did my son's Yaris this weekend. I got a Gates belt, which I like.
I thought I got it tight but the next day it started to squeal. I should of run it for 10 minutes and then gone back to re-tension the belt. As you said before, avoid the OCV. I went to the left of it, almost sort of sideways to apply tension.
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
seat belt chime disable? Lewis DIY / Maintenance / Service 19 05-25-2012 04:36 PM
HELP!? HORRIBLE drive home during first REAL Snow in Michigan, paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-11-2009 08:07 PM
HELP!? HORRIBLE drive home during first REAL Snow in Michigan paulyd0021 General Yaris / Vitz Discussion 32 12-10-2009 01:23 PM
Best Grease to use on the belt? hasher22 DIY / Maintenance / Service 11 04-23-2007 02:20 AM
