I am not sure what the dealer would charge, but replacing the belt is actually a very easy DIY. You loosen the upper and lower alternator bolts, move the alternator towards the engine block to remove it, slip the new one on in its place, hold tension on the alternator, and tighten the alternator bolts.
The one thing you have to be careful of is not breaking the OCV (the small cylindrical device on the left side of the engine) when holding tension on the alternator.
| Seat belt buzzer is silenced | billk | General Yaris / Vitz Discussion | 48 | 10-30-2013 09:58 AM |
| seat belt chime disable? | Lewis | DIY / Maintenance / Service | 19 | 05-25-2012 04:36 PM |
| HELP!? HORRIBLE drive home during first REAL Snow in Michigan, | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 12-11-2009 08:07 PM |
| HELP!? HORRIBLE drive home during first REAL Snow in Michigan | paulyd0021 | General Yaris / Vitz Discussion | 32 | 12-10-2009 01:23 PM |
| Best Grease to use on the belt? | hasher22 | DIY / Maintenance / Service | 11 | 04-23-2007 02:20 AM |
