#37 |
OK - I see that now too. I am coming up blank then on the actual rubber piece that goes inside of the two plastic cups. Unless there actually isn't one, and in the installed picture that I posted above, the black piece in the middle of the white is just simply the metal bushing from the middle of the OEM rubber piece.
#38 |
Here's a translation from a Japanese blog:
"TRD rear suspension arm sheet Inner / Outer (:48726-NP900 Number) is (:48726-NP910 Part). I mounted onto the rear arm bush, as sandwiched between inner and outer cover made of this Duracon. Rear left and right movement is restricted by it, there is no blurring. It is the cancellation of the rear toe control. When it comes to the effect, I did not see it not good impression of the effect of the strengthening of the front bush is too strong, he felt a sense of rigidity of the rear is better than before, as if conscious. Quick minute there is less sense of play out but I like to skate faster. Once you get used because you know the feeling of good start, but are easy to the control. To track run is much better - I'm afraid."
#39 | |
![]() ![]() ![]() Drives: 2012 Yaris SE Join Date: Nov 2011
You have to love Japanese to English translations too.
#40 |
0-60 in slow
I'm not seeing how they would work correctly. The outside of the bushing is solid so how would it articulate in a twist motion, think one wheel bump, and not bind? If it were the other way round I could see this bushing working correctly but you wouldn't get any help with the lateral movement issue.
Toyotas engineers aren't stupid so I have to imagine it works as intended, or its a bandaid issue to something they couldn't fix correctly given the rules allowed. |
#41 |
0-60 in slow
So out of curiosity sake, I asked a chassis engineer co-worker of mine the question on what will these bushings do?
His response... Since the axle is setup like this |/-\| the bushings will limit articulation movement and introduce bind, but that's not necessarily a bad thing. Under bump conditions since the axles are no longer able to pivot freely they deflect the trailing links on bump and cause a toe-out condition on both tires, and modeling how much bind is introduced you can use is as roll resistance rather than using springs or an ARB. In his opinion its a cheap way of solving a problem but not the correct way to solve the problem. |
#42 | |
Having the void area that is present in the stock torsion beam bushing has to result in some kind of weird lateral 'mush' when the suspension is worked hard. and I gather this is just a band-aid fix like you said without resorting to a steel bearing, which wouldn't work anyway. I do understand what you're saying now about the beam not necessarily rotating about axis of the torsion beam bushing on the Yaris. |
#43 |
0-60 in slow
The rear shock absorber is also being used as a lateral location device. There will always be some sort of bind on the axle but as long as your aware of how much bind is introduced it might not be a problem.
These are production cars not race cars so some issues just have to be worked around. |
#44 |
![]() Drives: 2009 3rd Polar white Join Date: Apr 2011
Couldn't you just fabricate a track bar for the rear axle? That would eliminate almost all the side to side movement, but not vertical, or even the torsional movement along the axle. It would only take some basic welding skills, some rod ends and some steel tubing (I would use DOM tubing). I have no idea which rang classes that would be legal in, however.
#45 |
That should read, "I have no idea which racing classes that would be legal in, however."
#46 |
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
deathbeard did u sell the rear sway bar?
#47 | |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#48 |
A watts link on our rear suspensions would be interesting... you could have the bars connect to a bracket off the lower shock bolt, and by keeping them very long, keep the "arc" motion down to a minimum...
#49 |
0-60 in slow
A watts link is right on the money.
I do have a basic design on the Watts link ready to go once I get clarification from the SCCA on what exactly defines a solid axle. The one thing that is a potential downside is that the parts will weigh 20-30 lbs which might be detrimental to the potential gains. There is no need to weld a beam you only need a solid mount at the lower shock point. I also have a plan for a track bar that is extremely simply to mount and install that would be legal in almost any sanctioned race body. The rear has 2 semi heavy duty tow mounts that have 2 holes already drilled in them that could provide an easy spot to mount a trac bar, the only thing that would be required is a slight reroute on the tailpipe. I do have another idea for a Anti-roll bar but that's going to be secret since it can create a potential failure in the axle over a long period of time. |
#50 | ||
2ZR swap. DO IT! Ask how!
The only class in the 2013 Solo rule book to call out a Watt's link by name is Prepared, in section 17.7:
#51 |
Obsessed with 1.5L
Sounds like a done deal
#52 | ||
0-60 in slow
#53 | |
http://www.richardaucock.com/astra-s...tive-engineer/
#54 |
0-60 in slow
^ And there you have the parts I'm going to be using.
Some models of the Chevy Cruze a watts link with a sum total of parts that would cost less then $200 to procure, and require only minor modification to the support beam and stabalizer arms to make them work in the way I'm trying to make them work. |
| My suspension setup: Breakfast Blend for the angry panda | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 07-26-2010 03:56 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
