Old 02-25-2013, 10:47 AM   #14
Originally Posted by NJ Drive View Post
Scott, out of the parts listed, only the two white resin rings are applicable to the torsion beam bushing. 48752-NP900 pertains to a replacement bushing that resides on the shock shaft, just above the dust boot.
OK - I see that now too. I am coming up blank then on the actual rubber piece that goes inside of the two plastic cups. Unless there actually isn't one, and in the installed picture that I posted above, the black piece in the middle of the white is just simply the metal bushing from the middle of the OEM rubber piece.
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 03:56 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
