![]() ![]() Drives: Yaris Join Date: Feb 2013
hi. I have indeed been able to remove the vertical pieces with no problem (number 1 & 2 as per picture above). However the number 3 should be removed to access the knob. since when I check the knob cover, it seems that it is in fact clip also to the radio cover.
That is correct. You will need to remove the radio mounting screws and pull the radio forward a bit to allow the AC panel to come off.
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 08:47 AM |
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
| Question about bi amping front components. | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 08-28-2010 12:04 PM |
| FS: OEM shocks, springs, front emblem, lug nuts, Delrin shift knob | Brentorius | Items for Sale by private party | 4 | 04-06-2010 07:40 AM |
