Old 03-04-2013, 06:13 AM   #1
bronsin
bronsin's Avatar
I know of nothing you can do to the car to reduce the effect of hitting potholes.
If your commute is potholy perhaps you can go another way?
Me Ive gone the same way to work for 34 years. So I know where the potholes are and position the car to miss them.
Same with driving around town.
Old 03-04-2013, 06:26 AM   #2
nookandcrannycar
LOL. Sounds as if you could almost drive to work with your eyes closed!
Old 03-04-2013, 07:38 PM   #3
jayeh
Drives: '08 Yaris LB
You haven't been to Ontario. I hit a pot hole so deep my car bottomed out. The worst part was I was already absolutely crawling.
It gets even worse at night and when they are filled with water and you can't judge the depth of them.
I'm pretty sure I've swerved so hard I've only had 3 wheels on the ground more than a couple of times to avoid some massive potholes.
jayeh is offline   Reply With Quote
Old 03-04-2013, 10:08 PM   #4
YodaBird
Drives: Gray
Thank you :) What can be done about it, to reduce the damage, once again I ask
YodaBird is offline   Reply With Quote
Old 03-04-2013, 10:42 PM   #5
jayeh
Nothing afaik.
I've got snow tires on OEM steel wheels, instead of lug centric shitty multifit steel wheels. That will reduce the risk of things going wrong in that department.
Short of finding some kind of light truck tire that would fit a yaris I'm not sure there is anything that can be done mechanically.
The best thing to do is avoid the bad roads. I take a longer/slower route downtown since the most direct route is too damn rough.
Old 03-04-2013, 11:29 PM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Sell your Yaris, get an SUV.
Still can't beat the potholes in Florida.
Oh wait, those aren't potholes.
Old 03-05-2013, 06:08 AM   #7
bronsin
bronsin's Avatar
Stubborn isnt he?
Old 03-05-2013, 01:06 PM   #8
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Stubborn isnt he?
I know, right?
How many people have to say, "There's not much you can do, other than avoid them" in slightly different ways does it take?
Nothing afaik. ... I'm not sure there is anything that can be done mechanically.
If your commute is potholy perhaps you can go another way? ...
... If your car is stock though, don't worry. Well worry about those wheels, because they bend easily.
The easiest way to help is get tires with lots of sidewall, and wheels that can handle a pounding. ...
Let me add my $0.02:
Originally Posted by jpmck03
There's not much you can do about your suspension, tires, wheel, etc. to help you not damage your suspension from doing what it's supposed to do anyways. But, you can try to avoid potholes.
Old 03-05-2013, 08:39 PM   #9
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by nookandcrannycar View Post
In my experience, roads (in general) are in a lot better condition in CA than they are in MA. Let's say (just to aid in my point) that you and AR 12 have exactly the same level of driving skill. I think AR 12 would have a better chance of avoiding potholes on the roads of CA than you would avoiding potholes on the roads of MA....but admittedly, I haven't driven out on your peninsula.
The roads are bad. Of course in winter every time it freezes new bumps and holes develop as well.
But seriously, sidewall. You put 60+ inches of sidewall and that should be enough cushioning to reduce impact a quite a bit. And good wheels. I have 14" forged wheels. In the 4 years I have owned them they have taken a pounding that would have destroyed more than a few stock wheels, and they are still perfect. I did destroy two stock wheels in the 2 years I drove the car before that as well.
As for other damage? You can't do anything but slow down and try and avoid them. I've hit my frame on the road because of a pothole before, can't really do anything except know the car should be able to take it.
There is no magic road flattener.
Colin Chapman disciple
Old 03-05-2013, 10:53 PM   #10
nookandcrannycar
Wow. I've encountered some bad roads in MA, but I'm glad I've managed to avoid the ones that triggered your description.
Old 03-05-2013, 11:48 PM   #11
nookandcrannycar
Are the public roads (overall) in Ontario worse than the roads in Saskatchewan? In Ontario I've driven from the Manitoba border on 17, through Thunder Bay, Marathon, Sault Ste. Marie, Sudbury, North Bay, to the 417, and through Ottawa to the Quebec border. I've also driven the 401 from the Quebec border to Windsor, and the QEW from Toronto to Niagara Falls. I've driven some surface streets in the Toronto Metro, the Windsor Metro, in Niagara Falls, in Ottawa, Thunder Bay, and in Sault Ste. Marie (this was mostly in 2006 and a bit in 2007, but also on another trip more than a decade earlier). Obviously, I didn't even 'stratch the surface' when it comes to roads driven on, but I found the roads in Quebec and especially in Saskatchewan to be worse than in Ontario. I was driving on the 16 from Edmonton to Saskatoon, and as soon as I hit the Alberta/Saskatchewan border, I was amazed by the negative change in the condition of the road. The road from Regina to the Manitoba border was a little better, but the surface streets in Regina were in terrible condition. The worst roads I encountered in Canada were in Newfoundland, but they weren't public roads -- they were private roads that belonged to various campgrounds.
License plate bracket for '09 that doesn't require putting holes in the bumper? BennyLava General Yaris / Vitz Discussion 16 03-10-2013 03:08 AM
I NEED to Figure a Way to Get More Front Seat Leg Room msmitka General Yaris / Vitz Discussion 25 09-08-2010 07:29 PM
How to fix pot holes. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 4 05-04-2010 04:43 PM
Punching Air Box Holes schreck Performance Modifications 11 05-07-2009 04:59 PM
Speaker grills / holes on the doors. IsLNdbOi Wash, Wax, Detailing, Exterior Repairs 3 09-15-2006 10:28 AM
