Old 03-07-2013, 07:34 PM   #11
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by malibuguy View Post
I thought about recreating the plenum when I go to do mine...just because the factory is so damn ugly. But I wonder if a larger volume could benift even more?
I unolcked some secrets in that "ugly" plenum...
There's a "reverse velocity stack" which extends into the center of that really small plenum.
And I noticed something else... even though the picture doesn't show it, nothing is at right angles or parellel to the plane of the runner entrances. Everyhing is cocked at odd angles including that velocity stack.
Now this could likely be for noise reduction as that seems to be a major consideration in passenger vehicles, or it could be to break up resonant harmonic frequences so as to smooth out the peaks and valleys in the power band over a wide rpm range. There is almost no information on the web about these intake manifold issues, so I'm going to go off in a direction which I think will work.
Because that's what life's all about...
...finding out.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
