Old 03-09-2013, 03:33 PM   #1099
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I'm going with a different concept that retains the existing rounded square base...
...to save the most costly and complex task of machining the 4 runner entrances. I already have some 6 inch tubing left over from the velocity stack spacer, and might use that. Although the other end will be something different if I can get a hold of the right materials.
Old 03-09-2013, 06:32 PM   #1100
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I had contemplated that, but then I would have to figure out how to weld up a rounded-square body. My idea was to match the radius of the base with some tubing, cut it into quarters, and weld panels between them. Given my lack of welding skill but substantial access to machining equipment, the tube + flanges seemed to make the most sense. It would still require someone to weld the seams, but tube-in-a-hole is easier than plates-hanging-in-space.
Old 03-10-2013, 12:11 AM   #1101
tooter
play every day
tooter's Avatar
The solution to that is simple.
A 6 inch diameter circular aluminium plate with a rounded square hole cut in the middle of it. I know a really competent welder who can weld anything. The secret to any project is finding good honest people who you can trust.
Old 03-10-2013, 10:17 AM   #1102
mr_miles
Drives: 2013 Yaris
I love this thread. I wish I was closer so that i could help :/
Old 03-10-2013, 03:40 PM   #1103
tooter
play every day
tooter's Avatar
That would be lots of fun...
Well, at least I can keep you posted every step of the way. I just ordered a part for the manifold plenum, and will post pics when it arrives. It's something which has absolutely no relation to engines, and I'm adapting it to an unintended purpose.
As far as I can tell from searching the web for everything about intake manifold design I could find... no one has built the design I'm going to try. There may be a reason. Because it doesn't work! But I'm going to find that out for myself. I'm building one manifold designated for testing only. And the good part is that if the experimental designs don't show any gains on the dyno, I can always simply cut them off of the runners and try something else.
Old 03-10-2013, 05:06 PM   #1104
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
If you are going to try a really large diameter plenum...large diameter equals low velocity.
Old 03-10-2013, 06:06 PM   #1105
tooter
play every day
tooter's Avatar
No, I won't be doing that. First off, there's no room for a larger plenum with this particular manifold design while keeping the air filter under the hood. And second I don't want to go larger. Instead, I'm going to a smaller plenum. The existing one is already almost non existent with that big thick intake tube occupying so much volume...
...and yet that design works great! I believe it is because of the unique configuration with all the runner entrances pointing directly at the bore of the throttle body...
That internal intake tube terminates only a couple of inches in front ot the runner's entrances. So there is very little plenum volume left over.
When I get the part, I'll be able to measure exactly how much smaller if at all by filling both plenums with water. What will be radically different is the profile of the new plenum. I literally dreamed up this crazy idea...
Old 03-11-2013, 11:31 AM   #1106
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Hey Tooter, I need to come up 2 LA and meet this welder of yours. I have a project I would like to run by him. Whereabouts is he located?
JustDidIt is offline   Reply With Quote
Old 03-11-2013, 06:40 PM   #1107
tooter
play every day
tooter's Avatar
Sure.
Ajax's
7933 Gloria Avenue
Van Nuys, CA 91406
818-781-5667
Bill is the owner.
Tell him tooter sent you.
His place is easy to get to as it's just West of the 405 off the Roscoe Boulevard exit.
West on Roscoe
South on Woodley
East on Strathern
South on Gloria
Old 03-11-2013, 07:50 PM   #1108
JustDidIt
JustDidIt's Avatar
Sure.
Ajax's
7933 Gloria Avenue
Van Nuys, CA 91406
818-781-5667
Bill is the owner.
West on Roscoe
South on Woodley
East on Strathern
South on Gloria
Awesome! Thank you!
Old 03-11-2013, 08:17 PM   #1109
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Cool Tooter! Are you reworking the manifold with your own plenum and TB mount?
Old 03-11-2013, 09:44 PM   #1110
tooter
play every day
tooter's Avatar
Yes.
I have a totally "outside the box" idea and am going to build up a tooter and dyno it just to see how the concept works.
Old 03-15-2013, 04:16 PM   #1111
tooter
play every day
tooter's Avatar
The new plenum came today, and it has nothing to do with intake manifolds. It's a structural architectural ornament. This is the basic layout of the experimental tooter...
I filled up both plenums with water to test the volume, and was totally suprised to discover that they both hold exactly 26 ounces! I'm always looking for omens and this is a really good one...
The old plenum appears to be a lot larger because there is so much material inside it which by displacement decreases the volume.
Old 03-15-2013, 04:50 PM   #1112
Phallic!
Old 03-15-2013, 06:21 PM   #1113
tooter
play every day
tooter's Avatar
To you, everything is phallic.
Old 03-15-2013, 10:01 PM   #1114
CrankyOldMan
Hmm, what about the 6" tube remnant?
Old 03-15-2013, 11:14 PM   #1115
tooter
play every day
tooter's Avatar
It's right here...
I think I'll try it without this time since the two plenum volumes already match. I can always cut off the hemisphere and add a ring later. And while the plenum is off I can clean up and smooth out the runner entrances.
Old 03-16-2013, 11:58 AM   #1116
CrankyOldMan
Yikes, those are some gnarly welds for a flow surface.
Thinking back to my own can-shaped design, the flow analysis showed that there was pretty much no air movement in the shoulder area of the TB side.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
