That is the one that I have. I just disassembled mine and hooked it up on my test bench to experiment with it. The clock and odometer are a separate assembly from the rest of the instrument cluster. Does anything at all display on the clock area of yours?
![]() Drives: Yaris 1.0L Join Date: Mar 2011
No nothing.Did you find something that can be replaced,or behind that LCD is a small electronic board.Maybe there is a malfunction,somethin broken or burned?
The small LCD (which is actually a vacuum fluorescent display) for the clock and odometer is a separate assembly, so that could be replaced as it may be the bad part. There are three separate circuit boards - The large main on, the one that the speedometer display is mounted to, and the "Core" board, which snaps to the back of the large board. The Core board contains the primary processor for the cluster and it has the EEPROM where the odometer data is stored. Unfortunately you can't buy the boards separately from Toyota, but if you can track down one from a wrecked Yaris, which has a cluster with the same part number, then you can either swap the clock/odometer display onto yours or you can swap your core onto it.
Yeah,but used clusters cost over 100$ on ebay,so it is a bit expensive.My dad is a electrician,so i wil disassemble the cluster and give him.Maybe he can find the problem.Anyway thank you for your response,i will notify you if i find something.
#5 | |
Ok,i am interested,tell me how we gonna do this.But i still need to be sure where is the problem with my clock.Give me few more days to test it,then i am going to let you know.
Here is the Pic of LCD.I was wondering this black spot in the right corner,is this ok.I mean I see on both of yours it is visible.Then again as i disassembled the speedo,it had also two of these marks,so i think this is ok.
#8 | |
![]() Drives: Yaris Join Date: Oct 2008
I am facing the same issue and will try to replace the clock from a donor cluster. In order to test the "new" cluster, can somebody point me the pinout of the connectors to be able to switch it on and see if the clock works?
It is an European Yaris, and part-number is 83800-0D660 Quote:
Drives: Yaris 2006 + CorollaVerso 2002 Join Date: May 2018
Hi all !
Same problem (for over a year now...) Happy to find this forum/threat. Are there any real solutions yet ? Thank's in advance ! |
#10 | |
It is only necessary to connect, pins 1 (12V) and 24 (GND) to power the unit outside of the vehicle. Now my plan is to swap the clock/temperature display of both units. |
| GI: "YarGauge" replacement clock module (Digital Tach, etc.) | CTScott | Items for Sale by private party | 756 | 03-21-2013 09:22 PM |
| 05 Echo changing time on clock | jambo101 | DIY / Maintenance / Service | 3 | 11-12-2011 05:34 AM |
| Dashboard mount for iPhone 4S? | shima | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-25-2011 10:22 AM |
| Dashboard remove ... ALL of it | Toji | Cosmetic Modifications (Exterior/Interior) | 7 | 02-26-2011 07:30 AM |
| Setting the clock after DST change | ToddR | DIY / Maintenance / Service | 10 | 03-10-2009 12:33 AM |
