Old 05-24-2018, 10:51 AM   #9
lespaulstd
Drives: Yaris
I am facing the same issue and will try to replace the clock from a donor cluster. In order to test the "new" cluster, can somebody point me the pinout of the connectors to be able to switch it on and see if the clock works?
It is an European Yaris, and part-number is 83800-0D660
That is the one that I have. I just disassembled mine and hooked it up on my test bench to experiment with it. The clock and odometer are a separate assembly from the rest of the instrument cluster. Does anything at all display on the clock area of yours?
Attachment 50263
Thanks in advance
lespaulstd is offline   Reply With Quote
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 09:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 05:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 10:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 07:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-10-2009 12:33 AM
