Old 04-16-2013, 06:12 PM   #1
eepp
Drives: Yaris 2008 RS
Fuel gauge: low fuel indicator
Hi everyone.
I bought a 2008 Yaris last year and I'm still wondering if there's a step past the flashing single bar of the fuel gauge to indicate low fuel. Is there some other low fuel light indicator (like I had in previous cars) after that or the car will eventually breakdown when this single last bar is flashing?
Thank you.
eepp is offline   Reply With Quote
Old 04-16-2013, 06:31 PM   #2
No. On the second generation Yaris there is just the slow and fast flash of that bar to warn you of being low.
Old 04-17-2013, 08:04 AM   #3
eepp
Thank you. So I believe I never saw both rates. How fast is fast?
Old 04-17-2013, 08:09 AM   #4
0.6 and 1.2 second flash intervals. The 1.2 second interval is when there is approx 1.6 gallons left in the tank and 0.6 is when there is less than 1.1 gallons left. The transition happens quickly enough that it is easy to miss the 1.2 second rate.
Old 04-17-2013, 08:19 AM   #5
eepp
Ok thank you CTScott!
Old 04-17-2013, 09:08 AM   #6
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I usually start looking for a place to fill up when she is blinking regardless of the rate. Either that or somewhere around 400 miles on a tank.
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 04-17-2013, 08:15 PM   #7
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Mine goes from 2 bars to flashing I don't seem to have 1 bar
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 04-17-2013, 08:21 PM   #8
The single bar only appears flashing.
Old 04-25-2013, 05:28 AM   #9
lamadoo
Drives: 2007 Yaris 3door white
Was reading some past threads.
I read that we should not let it drop to 1 bar (blinking). Always try and keep it at minimum 2 bars because you don't want your yaris running low and on fumes. All the gunk in the fuel filter will get stirred and stuff, if someone with more knowledge can explain better.
The fuel filter is extremely difficult to change, some say its unserviceable so we should take care of it and use decent fuel on top
lamadoo is offline   Reply With Quote
Old 04-25-2013, 07:33 PM   #10
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
Also keep in mind that some of us have had problems with the fuel gauge not reading correctly, so that it reads as 1/4 full, but you're almost out of gas. Keep track of your miles with the odometer so you don't run out of gas.
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 04-25-2013, 10:00 PM   #11
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
That depends on what your car is doing. I wait to the bar is flashing to fill it, and I have never had to put more than 10.5 gallons in. An entire gallon is plenty extra.
But that is my car, all Yaris' seem to be different in this regard.
Colin Chapman disciple
Old 04-26-2013, 07:32 AM   #12
ciscobear
Drives: Toyota Belta
I let mine go fast flash before refilling, I'm always tracking my mileage however. Sometimes it takes long to go from slow flash to fast, sometimes it feels like it is almost immediate.....I'm like wtf. So track via mileage :)
ciscobear is offline   Reply With Quote
Old 04-26-2013, 08:56 AM   #13
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
I got no bar at one time .
Battery was dead. I think that was the sign of the fuel pump not working, the motor couldn't even crank.
On topic: on my Yaris, the last bar starts blinking fast when there's about 12 litres (~3.2 gallons) of gas left.
I once drove for another 100 km (62 miles) and still had about 5 liters left in the tank.
However, I suggest refuelling as soon as possible, as you could potentially burn out your fuel pump driving extendedly with low fuel.
(Gasoline has a cooling effect on the fuel pump.)
Mittelklasse is offline   Reply With Quote
Old 04-26-2013, 06:49 PM   #14
jayeh
Drives: '08 Yaris LB
400 MILES
I once got 380 miles on a tank, but that was a rarity.
jayeh is offline   Reply With Quote
Old 04-26-2013, 07:16 PM   #15
nookandcrannycar
Originally Posted by jayeh View Post
400 MILES
I get over 500 miles on almost every tank. The official capacity of the tank is what, 11.1 gallons? However, the 'absolute' capacity (for lack of a better phrase) as demonstrated by CTScott's calculation (and my own 12.777 gallon fill up) is 12.8 gallons.
Old 04-26-2013, 07:24 PM   #16
jayeh
Are you guys going to empty?
Old 04-26-2013, 09:29 PM   #17
nookandcrannycar
The 12.777 gallon fill up = when I ran out of gas while pulling up to a pump to get gas. My usual fill up is probably between 12 and 12.5 gallons. I pay ettention to how many miles I'm getting from each bar on the current tank as well as the total miles so far on a current tank when deciding when to fill up.
Old 04-26-2013, 07:24 PM   #18
why?
why?'s Avatar
Drives: Yaris LB
The fuel pump is actually submerged in gas. To run it dry means you would have to get every single drop of gas out of the tank first.
Tags
fuel gauge
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel low light issue Kitt DIY / Maintenance / Service 3 03-22-2007 01:44 PM
