Old 04-26-2013, 08:56 AM   #1
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
I got no bar at one time .
Battery was dead. I think that was the sign of the fuel pump not working, the motor couldn't even crank.
On topic: on my Yaris, the last bar starts blinking fast when there's about 12 litres (~3.2 gallons) of gas left.
I once drove for another 100 km (62 miles) and still had about 5 liters left in the tank.
However, I suggest refuelling as soon as possible, as you could potentially burn out your fuel pump driving extendedly with low fuel.
(Gasoline has a cooling effect on the fuel pump.)
Mittelklasse is offline   Reply With Quote
Old 04-26-2013, 06:49 PM   #2
jayeh
Drives: '08 Yaris LB
Originally Posted by BEEF View Post
I usually start looking for a place to fill up when she is blinking regardless of the rate. Either that or somewhere around 400 miles on a tank.
400 MILES
I once got 380 miles on a tank, but that was a rarity.
jayeh is offline   Reply With Quote
Old 04-26-2013, 07:16 PM   #3
nookandcrannycar
Originally Posted by jayeh View Post
400 MILES
I get over 500 miles on almost every tank. The official capacity of the tank is what, 11.1 gallons? However, the 'absolute' capacity (for lack of a better phrase) as demonstrated by CTScott's calculation (and my own 12.777 gallon fill up) is 12.8 gallons.
Old 04-26-2013, 07:24 PM   #4
jayeh
Are you guys going to empty?
Old 04-26-2013, 09:29 PM   #5
nookandcrannycar
The 12.777 gallon fill up = when I ran out of gas while pulling up to a pump to get gas. My usual fill up is probably between 12 and 12.5 gallons. I pay ettention to how many miles I'm getting from each bar on the current tank as well as the total miles so far on a current tank when deciding when to fill up.
Old 04-26-2013, 09:31 PM   #6
jayeh
Most are mine are in the 8-9 gallon range. Makes more sense now.
Old 04-28-2013, 10:06 AM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Also note nookandcrannycar fills the tank until he can see the gas.
Colin Chapman disciple
Old 04-28-2013, 02:19 PM   #8
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
What I would like to do is add more capacity to my gas tank. I have often toyed with the idea of getting a 20 gallon tank. You could go a long way or a long time without gassing up.
I wonder how hard it would be to drop the OEM tank and get an aftermarket tank. How would that effect the gas gauge?
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 04-26-2013, 11:21 PM   #9
nookandcrannycar
Oops. I do know how to spell attention .
Old 04-26-2013, 07:24 PM   #10
why?
why?'s Avatar
Drives: Yaris LB
The fuel pump is actually submerged in gas. To run it dry means you would have to get every single drop of gas out of the tank first.
fuel gauge
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel low light issue Kitt DIY / Maintenance / Service 3 03-22-2007 01:44 PM
