Old 05-20-2013, 02:56 PM   #1
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Very cool! One of my concerns would be the possible overloading of the alternator due to the very low internal resistance (fast charging rate) of the caps. I don't know if the alternator is self limited in peak output, or if the battery holds it back.
The biggest concern is the possibility of having to charge it after not using the car for a few days. Since mine rarely gets even one day off this should not be a problem.
One other concern would be the possibilities of voltage surges exceeding 16.2 volts. I might consider placing an appropriate sized zener across the caps, but the super caps themselves should help prevent such surges anyways.
I will follow your results with a great deal of interest.
If this seems to pan out I will replace my own battery in a couple of years this way. I'd just as soon get all the use out of the original battery that I can.
Perhaps a much smaller standard battery along with the caps could keep the charge up for several weeks and still start the car.
Amdkt7 is offline   Reply With Quote
Old 05-20-2013, 03:03 PM   #2
The voltage regulator module, within the alternator, would be the first to fail if the current draw by the caps is too much. Thus far I have seen a peak current draw of 45A, which is well within the 70A rating of the stock alternator.
The zener diode is not a bad idea to prevent damage from over voltage, but there again the voltage regulators in modern cars generally prevent that type of failure mode. I will eventually add a large rectifier diode to the pack to prevent the possibility of reverse polarity, as that would result in the most catastrophic failure.
Old 05-20-2013, 08:06 PM   #3
nookandcrannycar
I have a somewhat related question. IIRC, it was the voltage regulator that was the 'failure issue' re the alternator on 2007 (only) Yarii. Sears put a remanufactured alternator from a local company (this happened near Minneapolis) in my Yaris. Would that remanufactured alternator have to have been from a 2007 to work properly long term? If not, I assume I could currently have a 2008, 2009, or 2010 alternator (I did this replacement in 2010)? Is there any way I can tell the 'model year affiliation' (for lack of a better phrase) of this remanufactured alternator that is currently in my Yaris? (Sorry re the extra question).
Old 05-20-2013, 09:56 PM   #4
Any year alternator will work, but ideally you want a late 08 or newer to have a post TSB voltage regulator. If yours is remanufactured you would have to open it to check the part number on the voltage regulator to see if it is pre or post TSB.
Old 05-21-2013, 01:49 AM   #5
nookandcrannycar
Thanks so much for the great info! I'd like to know, but not enough to open up the alternator.
battery, supercapacitor, ultracapacitor
Would an All-Electric yaris be cheaper in the long run? captainm27 General Yaris / Vitz Discussion 52 02-10-2010 02:35 PM
anyone know the benifits of lightweight wheels? BrazdonW Wheels, Tires and Suspension Forum sponsored by The Tire Rack 59 07-16-2007 09:22 PM
