#1 | |
The voltage regulator module, within the alternator, would be the first to fail if the current draw by the caps is too much. Thus far I have seen a peak current draw of 45A, which is well within the 70A rating of the stock alternator. The zener diode is not a bad idea to prevent damage from over voltage, but there again the voltage regulators in modern cars generally prevent that type of failure mode. I will eventually add a large rectifier diode to the pack to prevent the possibility of reverse polarity, as that would result in the most catastrophic failure.
#2 | |
#3 | |
#4 | |
| Tags |
| battery, supercapacitor, ultracapacitor |
| Would an All-Electric yaris be cheaper in the long run? | captainm27 | General Yaris / Vitz Discussion | 52 | 02-10-2010 02:35 PM |
| anyone know the benifits of lightweight wheels? | BrazdonW | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 59 | 07-16-2007 09:22 PM |
