Old 06-22-2013, 03:29 AM   #1
yariseggvvti
Drives: Yaris Hatchieback
Originally Posted by auxmike View Post
Is this it?
It's real easy to bust off the black connector when fooling with the waterpump or alternator.
Found oil leak from this valve. It seems like the O-ring is bad.
Has anyone replace this valve?
Thanks!
yariseggvvti is offline   Reply With Quote
Tags
error code, pump, sensor, variable valve timing
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
gude-head-1NZ-FE GnomeBody Performance Modifications 222 03-25-2011 02:32 PM
Ferrea valve upgrade kit cali yaris Micro Image 4 07-28-2010 11:52 AM
Want to connect a sub/amp to your factory HU? Navone N-85V Variable LineOut Convertor rningonfumes Items for Sale by private party 0 03-18-2010 10:39 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
