Old 06-22-2013, 07:35 AM   #1
Originally Posted by s210281 View Post
Hi there,
Same issue with my 2010 Yaris Hatchback. Trunk light simply won't work. Checked the bulb (continuity test + direct connection with a small 12V Battery) and it works fine. Check all the fuses in both fuse boxes (under the dashboard + under the hood) and they are all OK. Running out of ideas now ...any ideas or experience sharing will be much appreciated.
Other possibilities:
1. The Trunk switch needs to be checked ..but how ?
2. Damaged wire or something !!!
3. Some relay not working properly ..how to check ?
Best Regards
The hatch light works directly off the 15A DOME fuse in the under hood fuse panel. If that fuse is good, you can check out the hatch switch by pulling the hatch plastic panel and checking the brown wire from the latch. With the hatch open that wire should show continuity to ground.
Remote trunk opener Dec24th Cosmetic Modifications (Exterior/Interior) 16 01-29-2016 09:18 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Adding Power Trunk Release Ideas...Need Help Jrilla DIY / Maintenance / Service 12 08-23-2009 02:38 PM
xb side marker swap? funkstrong Cosmetic Modifications (Exterior/Interior) 4 10-25-2006 11:32 AM
