Old 06-22-2013, 04:01 AM   #2
s210281
Drives: Toyota Yaris/Vitz
Hi there,
Same issue with my 2010 Yaris Hatchback. Trunk light simply won't work. Checked the bulb (continuity test + direct connection with a small 12V Battery) and it works fine. Check all the fuses in both fuse boxes (under the dashboard + under the hood) and they are all OK. Running out of ideas now ...any ideas or experience sharing will be much appreciated.
Other possibilities:
1. The Trunk switch needs to be checked ..but how ?
2. Damaged wire or something !!!
3. Some relay not working properly ..how to check ?
Best Regards
s210281 is offline   Reply With Quote
Remote trunk opener Dec24th Cosmetic Modifications (Exterior/Interior) 16 01-29-2016 09:18 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Adding Power Trunk Release Ideas...Need Help Jrilla DIY / Maintenance / Service 12 08-23-2009 02:38 PM
xb side marker swap? funkstrong Cosmetic Modifications (Exterior/Interior) 4 10-25-2006 11:32 AM
