Old 06-26-2013, 07:52 PM   #1
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
If you're using the stock Toyota belt the mark you made might be right.But if you use an after market belt. It's not the same size as the Factory spec belt and it might be one of those elastic type like DAYCO which stretches and have to be PRIED BAR to tighten.
Old 06-26-2013, 08:37 PM   #2
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Mine still squeals to this very day...
Originally Posted by junorico24 View Post
... one of those elastic type like DAYCO which stretches and have to be PRIED BAR to tighten.
Probably my problem... anyone have a suggestion for a good belt brand for a replacement?
Old 06-26-2013, 09:16 PM   #3
The Goodyear Gatorbacks aren't bad, but I prefer Gates.
Old 06-26-2013, 11:03 PM   #4
junorico24
junorico24's Avatar
Went to the dealer an ordered the stocky Yari belt. No squeal Took the Dayco belt to the trash
Old 06-27-2013, 10:53 AM   #5
esse10
Drives: 2009 yaris 2 door
belt
Glad i saw this because I was thinking of buying a DAYCO brand . Guess Ill buy the GATES now............." IF it's good enough for CTSCOTT it's good enough for me" . I think the dayco belt would work ok in those cars with automatic spring loaded belt pulley tensioner.
esse10 is offline   Reply With Quote
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Seat Belt Problem wagon DIY / Maintenance / Service 1 03-06-2013 10:37 AM
Yaris problems heavenswaitin DIY / Maintenance / Service 3 11-02-2011 01:08 PM
NST Crank Pulley Reliability? WeeYari Performance Modifications 59 02-10-2010 01:20 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
