#1 | |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
That and the TB swap are the easiest. When I get some time this weekend I'll first try the TB and then the Thermostat. Will |
Based on Jason's expertise, I would do the thermostat first. As a quick and dirty test today, drive it and see if the green coolant light goes off. If it stays on and green, then you are in "cold start" mode. If it goes out, then the thermostat is likely not the issue.
#3 | |
um???? I think I have a blue???? light when the engine is cold, but it goes out almost instantly in the summer, and only stays on briefly in the fall and spring. I actually know the exact water temps because I've been driving around staring at my Scan Guage. ............................??? |
#4 | |
What are you seeing for temps? Normally the Yaris will sit in the low to mid 180's F when cruising.
#5 | |
I'll take my toy (The Yaris) for a drive tonight and pay attention to both the color of the light (when the car starts) and the water temp (in deg F) Will |
For my car on the freeway, my coolant runs between 179-184*. City driving goes from 180-190's. Parking lot goes up to 202, or around there where the fan kicks in. lol
#8 | |
I drove it briefly yesterday and I was seeing temps in the 140 - 175 range when cruising (outside temperature was approx 91) |
#9 | |
play every day
Be sure to let me know what happens, because if you're not satisfied, you get your money back. ![]() Greg |
#10 | |
Once the engine gets past the cold start range, the coolant temperature is still used for camshaft timing control: "Camshaft timing control is performed according to engine operating conditions such as the intake air volume, throttle valve position and engine coolant temperature." So, I still think that Jason's take on the performance thermostat being the culprit has merit.
| DC Sports Header install and evaluation | Loren | Performance Modifications | 217 | 07-04-2017 06:40 AM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 04:36 PM |
| Megan Racing header install and review with pics. | Herbicidal | Performance Modifications | 6 | 09-03-2009 08:40 AM |
| Pre Hack Revival: Megan Racing Header vs Ebay Header | Sabretooth | Performance Modifications | 15 | 08-19-2009 05:26 PM |
