Old 08-07-2013, 10:57 AM   #11
3cyltrbo
Originally Posted by Jason@SportsCar View Post
You would be surprised at how a thermostat can put a car out of whack... This past weekend I helped my neighbor install a thermostat in his work van. It failed emissions, when he got the ECU scanned by a GM tech it was stuck in open loop mode, and would not get above 150f - which is about the temp of that unit you put it. In his case when he had the radiator replaced a few months back some knuckle head cut the core out of the thermostat (no idea why, could have been stuck), we put a new stock one in and now it passes smog.
I run a cooler unit, because we run a 30-40 min race and spin over 7000rpm, but I have complete control of my fuel via my AEM ecu.
On a road going car with a stock ECU you have done nothing but fatten up the mixture. No upside.
Its an easy enough swap (the thermostat) except for having to replace the leaked coolant - so I think I'll try swapping it back.
That and the TB swap are the easiest.
When I get some time this weekend I'll first try the TB and then the Thermostat.
Will
3cyltrbo is offline   Reply With Quote
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
