Since the high beam does come on when you hold the stalk in the flash position, I would actually suspect the stalk as the problem. You can try jumping (on the headlight stalk connector) the black/white wire in pin 8 to the white/black wire in pin 11 to see if the low beams light up. If they do, then you definitely need a new switch.
| Tags |
| fuses, headlights, help! |
| headlights not working.... | Judas Iscariot | DIY / Maintenance / Service | 66 | 09-05-2019 11:27 PM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| Headlights stopped working - need help | Split | Cosmetic Modifications (Exterior/Interior) | 2 | 03-02-2012 11:04 AM |
| Dome/Floor Light and Headlights on Warning Not Working | danno7263 | DIY / Maintenance / Service | 4 | 05-24-2011 10:35 AM |
