Old 08-12-2011, 11:09 AM   #1
Split
Drives: 2008 Yaris Sedan
Question Headlights stopped working - need help
Hello YarisWorld,
A couple of years ago I installed a 55w HID kit (moving type hi/lo) which worked flawlessly until today. For some reason both headlights went out. I checked all fuses under the fuse box and none were blown. Does anyone have any suggestions?
Split is offline   Reply With Quote
Old 08-12-2011, 11:23 AM   #2
did you just do a visual check or did you test them with a volt meter? Sometimes they look ok but are actually popped.
Next check for voltage at the connector for the ballasts, NOT at the bulb. The HID bulbs use extremely high voltage to start.
Old 03-02-2012, 11:04 AM   #3
Split
^ i ended up just putting in a brand new kit with relays and doing it from scratch. no idea what it was, but its all fixed now. upgraded from 5000k HIDs to 4500k HIDs while i'm at it. Its brighter and less cheap looking now.
headlights not working.... Judas Iscariot DIY / Maintenance / Service 66 09-05-2019 11:27 PM
My car's electrical system just stopped working today..? jamhot18 DIY / Maintenance / Service 14 11-04-2018 01:40 AM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
Electric Windows Stopped Working !?!? MattyP DIY / Maintenance / Service 0 09-14-2010 07:20 AM
Help! Horn just stopped working. steveh74 General Yaris / Vitz Discussion 14 09-17-2009 10:23 AM
