![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
No reason to upgrade, the rears are just along for the ride. I have three years of racing on the OE rear shoes, and they still look like new - I ordered a brand new set of OE shoes last year thinking the old ones might be getting thin, when I opened the box and compared the only difference was old set is dirty.
![]() On our 2012 Yaris we actually ended up grinding away a good portion of the rear shoe to balance the brake bias, because when we disabled the ABS (as required by our classes rules) the rear was locking up way to frequently.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#2 | |
![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
By disable the ABS function, our brake bias between the front and rear will change? Base on your explanation, removing ABS function itself will lock up your rear wheel. Meaning more biting on rear drum than before.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
![]() Drives: 2011 Yaris 3dr Join Date: May 2013
I think he was saying that without the ABS actuator modulating the brakes, the rears locked up with little braking force. You have to remember he's tracking his car, so he hits the brakes hard. If you hit the brakes hard enough to activate the ABS, you know when the ABS actuator is modulating the brakes, it's loud and you can feel it it.
#4 | |
The front brakes do about 80% of the work, if you want better braking upgrade the front pads.
#5 | |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Drum brake/parking brake | devinlamothe | DIY / Maintenance / Service | 0 | 04-14-2012 08:30 PM |
| Parking Brake Shoe Adjustment | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-14-2009 02:26 PM |
