#4 | |
![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
By disable the ABS function, our brake bias between the front and rear will change? Base on your explanation, removing ABS function itself will lock up your rear wheel. Meaning more biting on rear drum than before.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Drum brake/parking brake | devinlamothe | DIY / Maintenance / Service | 0 | 04-14-2012 08:30 PM |
| Parking Brake Shoe Adjustment | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-14-2009 02:26 PM |
