Old 11-22-2013, 10:18 PM   #11
nookandcrannycar
I keep forgetting to post that this now includes 2007 to 2012 Yaris per T-SB-0078-12.
The newer TSB no longer specifies VIN range, but rather just says that:
"Some 2007 – 2012 model year Yaris vehicles may exhibit a noise from the front area that is heard under acceleration/deceleration, when braking, or when driving over an uneven road surface. New No. 2 front lower suspension arm bolts are now available to address this condition."
The current bolt part number per the TSB is: 90119-14151
It also mentions that some bolts may have and orange dot on the head and those that do are non-reusable, where ones without the orange dot can be removed and retorqued.
Earlier posts of yours (IIRC) indicated that the old part number ended in 126 (for 2006-2009?) and the other part number (not ending in 151) = for 2010+....and that 151 replaces both part numbers so that the full range = one part number rather than two. When I visited the dealer, the parts rep indicated = exactly as you described (however that was ).
The tech today (at the shop, not the Toyota dealer) had some other reference nomenclature for this bolt, so I just logged on and showed the manager the picture of the bottom of your Yaris with the red circles you put around the two bolt locations. So clear. The manager was then able to easily communicate this to the tech .
I remember noticing, when I picked up the new bolts at the dealer, a 'raised stamp' (forgive the Layman's term ) that I assumed indicated that they each = a 'No. 2'.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
