Old 01-06-2014, 12:17 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
They must have changed it at some point. Mine turned brown on the end and I found it impossible to read the oil level.
Old 09-15-2015, 06:28 AM   #2
bronsin
bronsin's Avatar
When the one on my yaris and wifes Camry turned brown I just cleaned them with scotchbrite and gasoline.
You definitely don't want to be checking the metal dipstick in bright sunlite. Wait for a cloudy day. Also, newly changed oil is much harder to see than 2000 mile old oil. But when draining all the oil and refilling with 3.7 quarts and changing the oil filter, its not necessary to absolutely check the oil with the dipstick. My 09 came with an overfilled oil sump as read on the dipstick. I thought "Toyota isn't going to overfill the sump at the factory." WRONG. More than four quarts came out when I changed the oil at 600 miles and the oil pressure sender blew at 28000.
Yaris XP9 diesel 90hp burning oil bubu DIY / Maintenance / Service 3 12-04-2013 02:08 PM
oil yaris 2008, 1.0 1krzys Cosmetic Modifications (Exterior/Interior) 1 10-18-2011 08:18 AM
Did they increase the oil capacity for 09 Yaris? 2007yariz DIY / Maintenance / Service 8 05-18-2011 09:28 PM
oil viscosity in 2009 yaris matanfr DIY / Maintenance / Service 20 05-18-2010 12:31 PM
