![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
Check engine light on high revs
I found this previous post and was wondering if anyone has any more info since I had this happen to me today. http://www.yarisworld.com/forums/showthread.php?t=6133
I was about to merge on to a highway and put my shifter into 2 and floored it and it the car started to accelerate, then around 5k rpm dropped down about 500rpm, flashed the check engine light, I let off and reapplied the gas and it did it again. It happened about 4-5 times along the way too. It was cold out but the car was warmed up. No codes were shown, no idea what is up. Seems fine on the way home. ![]() any ideas? |
Misfires. Either you are due for plugs or you have a coil on the way out. If you have access to a code reader that can read historical as well as current codes you would be able to verify which cylinder the misfire was on.
#3 | |
![]() I've got a scan gauge connected. It was the first thing I checked after I parked. |
ScanGauge only shows current not historical codes. You would need a more sophisticated reader for that.
#5 | |
Whats the logic behind the gas cap being loose causing the CEL to stay on, but a misfire doesn't even make it stay on? |
Correct. A simple scanner will only show codes when the CEL is on. Smarter tools, like TechStream, show codes that occurred previously, but since have self cleared.
El Huevo
Drives: 2007 Liftback Join Date: Aug 2006
Had this happen to me a few years back and in my case it was the spark plugs, you may want to check them.
#8 | |
Thanks guys. |
| Check Engine light and advance track light on | 20104dr | DIY / Maintenance / Service | 2 | 10-31-2013 09:59 PM |
| Check Engine Light on at 32k kilometers? | caper26 | DIY / Maintenance / Service | 21 | 10-16-2013 12:27 PM |
| Cold air intake....check engine light on...??? | JohnnyMalice | Performance Modifications | 4 | 04-29-2012 09:46 PM |
| Check engine light | Mr Yarisman | Performance Modifications | 7 | 10-24-2009 11:10 PM |
