Old 04-09-2007, 03:41 PM   #1
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
Some rca's actually run the remote turn on with the RCA cables because in theory they are both running to the back of the head unit...
If you ran them seperately I would say the next thing to look at is the grounds for the amps, make sure you picked a good ground...
Do a search and I am sure you will find multiple posts on where everyone grounded.........
Also make sure you check the pre amp, i tried hooking up a equalizer before and had tons of noise through it no matter where my ground was. Without it hooked up no problem whatsoever...
Just double check your connections, I am sure you will find something....
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Anyone Else having this problem???? MeggiemobileSFLA DIY / Maintenance / Service 3 03-01-2007 05:37 PM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
