Old 03-18-2014, 04:13 PM   #1
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Alright, I'll check with Garm too.
So if I get a fixed pulley can I just bolt it onto the supercharger?
Black_griffin6 is offline   Reply With Quote
Old 03-18-2014, 04:35 PM   #2
Yes - In place of the clutch pulley assembly.
At that point you will no longer use the Blitz fuel controller though. You will need to go with another form of fuel management.
You could also modify the existing clutched pulley to make it fixed.
Old 03-18-2014, 05:53 PM   #3
Black_griffin6
I have the Aem F/IC hooked up, but it's not currently on. I'm using the bypass wire.
When I tried to start the car after the installation of the supercharger, I had the FIC hooked up and it wouldn't start, not sure what the map is on there since it's a used unit.
Do you think the Aem piggyback would work?
How could I mod the current clutch pulley to be fixed?
Old 03-18-2014, 08:35 PM   #4
The F/IC would be fine for tuning it.
For converting the bad clutch to fixed, the simplest way to do so would be to weld the two sides together.
Old 03-18-2014, 08:56 PM   #5
Black_griffin6
Okay, excellent.
Would I need a waste gate or blow off valve?
Old 03-18-2014, 09:49 PM   #6
Okay, excellent.
No. The clutch does not disengage to allow the unit to blow off, so it seems to be internally limited, or perhaps limited by RPM.
I did see someone with an underdrive pulley mention producing more than the 6psi that mine tops out at.
FS: BLITZ SUPERCHARGER SPROCKIT Items for Sale by private party 17 02-12-2014 04:39 PM
fs blitz supercharger staypuft Items for Sale by private party 3 10-12-2010 06:58 PM
anyone with Blitz supercharger? yrsdrgn Performance Modifications 52 08-24-2010 07:57 AM
So Whats Blitz Supercharger 0-60 run??? marcus Performance Modifications 19 10-02-2009 06:59 PM
fixed my blitz s/c problem for now laszlo Forced Induction Forum 3 04-19-2009 10:24 PM
