#127 |
PM sent
#128 |
![]() Drives: 07 Yaris Join Date: Mar 2014
Interested in purchasing
Do you still have any these?
07 sedan m/t. Cost as well. Thanks |
#129 |
Yes. PM sent.
#130 |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Please send me the pricing & payment info also.
I have a 2007 hatch. Does your kit include everything necessary? Thanks Nortonfb 68 Norton fastback (Steve) |
#131 |
PM Sent. The kit includes everything necessary, other than the tools to do the install.
#132 |
![]() ![]() Drives: '15 Dodge Challenger Join Date: Aug 2011
ive got a 2007 sedan, can you pm me with the price and what i would have to do to install? thanks
#133 |
PM sent
#134 |
Super fast shipping, install not too bad, fishing the wires was def the hardest part. But I cant seem to get it to function on my 07 m/t sedan. I have tried rechecking all the connections and triple check the clutch switch to ensure it is fully pressed in when the my foot is off the clutch pedal.
Any suggestions of what to check? My wire coming out of pin 40 on the ECM is hooked up and ran through the firewall. I connected this directly to the wire coming out of the slot 1 of the D3 connector. Is this ok or do I need a different wire? If so what is it where do I get it |
#135 | |
Also, with the ignition switch in the ON position, you can measure the voltage on the pin1 wire and will see 12V if it is connected properly. (Pin 1 is the one that goes to pin 40 on the ECM connector). Also, double check your pin 40 to make sure you didn't install it on the opposite side of where it belongs.
#136 |
Checked pin 1 and 2 and Im happy with them. Rechecked pin 40 also happy with that.
Checked the voltage. I put my red lead on the connection between the pin 1 wire and the pin 40 ecm wire. Then I put my black lead on the bolt where pin 2 from the d3 connection is mounted. I get 12 v with the ignition turned on. Holding and toggling the cruise on/off switch does NOT make change and still reads 12 volts. Where the pin 2 wire is mounted there is a black lead already connected to that, I just added on the pin 2 wire and put the bolt back on. |
#137 | |
The black wire is not pin two. It is in the opposite row from pin 2. In this picture you can see the blue wire in pin 1 and the brown in pin 2: Conn D3.jpg
#138 |
My D3 connector looks just like the one pictured. The wires sent are different colors but going off the colors shown in the picture. The blue one connects directly to the A21 pin 40 wire. The brown one goes to a bolt (for grounding).
#139 |
"4.8. Splice the ECM pin wire to the piece of 18-22 AWG wire using a butt splice or
solder and heat shrink tubing." Do I really need to do that because the wire you sent me is long enough to reach the D3 connector. |
#140 |
No. They are long enough to reach with how I ship them now.
#141 |
Got the issue resolved, I now HAVE CRUISE!! Pretty sure this just doubled the value of my car. So happy about this.
#142 |
And buy your stuff from CTScott. He does all the BS work so you don't have to and everything comes ready to hook up. Fast shipping, good customer service, and it was pretty fricken cheap too. Scotts the man.
#143 |
![]() Drives: 2008 Yaris Join Date: May 2014
I ran across this forum while searching for a solution for a Yaris without cruise.
I'm needing to make twice weekly 250 mile trips and unfortunately am finding it difficult keeping a constant speed with old worn out feet and legs. I have an 2008 Yaris hatchback (base) with a manual transmission. Are the cruise control kits still available? Thanks |
#144 |
CT Scott has them. Drop him a PM.
Steve |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Can we do this? (aka The DIY Cruise Control Thread) | mrbond | DIY / Maintenance / Service | 502 | 07-22-2017 02:57 PM |
| This is pretty frikken stupid - Yaris '07 LB auto cruise control | firemachine69 | DIY / Maintenance / Service | 10 | 07-20-2010 08:09 AM |
