Old 12-20-2010, 01:54 PM   #1
FS: OEM Cruise Control Stalk with Wire and Screws
I have a couple of brand new, OEM cruise control stalks with the cruise control wire that connects the stalk to the clock spring and the two mounting screws. If you're in the CT area, I can give you a hand with the installation.
I also have the pins necessary for installing it on a 2008 and older Liftback or a 2009 and older Sedan:
http://www.yarisworld.com/forums/showthread.php?t=31763
Old 12-20-2010, 03:26 PM   #2
yaris2010RS
yaris2010RS's Avatar
please pm me with ur paypal and when i get home from work tonight i will send u funds.
Old 12-20-2010, 10:55 PM   #3
EckoDG
Banned NOT!
Drives: Car
scott, my 2010 sedan will no be available? :( cant fit? :(
EckoDG is offline   Reply With Quote
Old 12-20-2010, 11:14 PM   #4
It will fit a 2010 Sedan.
Magnum23 installed cruise control on his 2009 Sedan. His Puerto Rico spec Yaris had the wiring at the steering column, but did not have the wire from the ECM to the column, so he had to run that wire to make it work on his.
Look at this page of this thread for more info:
http://www.yarisworld.com/forums/sho...to+rico&page=3
Old 12-21-2010, 05:13 AM   #5
magnum23
Drives: Blue,Sedan
That's correct, Eckodg contact me if you need any help
magnum23 is offline   Reply With Quote
Old 12-22-2010, 08:39 PM   #6
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Pins?
I thought 08 yaris is screwed for CC?
Blah, Blah, Blah, Blah
Saggio is offline   Reply With Quote
Old 12-22-2010, 08:50 PM   #7
Originally Posted by Saggio View Post
Pins?
Check out this thread for all of the details, but in a nutshell all 06 to present US and Canadian Yaris ECMs have had the functionality built it.
http://www.yarisworld.com/forums/sho...ght=faq+cruise
Old 12-22-2010, 09:59 PM   #8
vhicke
Drives: yaris
scott do you have a diy kit that i can get as i have a 2008 yaris sedan and just want the easy way....let me know...thanks
vhicke is offline   Reply With Quote
Old 12-22-2010, 11:18 PM   #9
YAR1S
YAR1S's Avatar
Is this DIY fairly easy or difficult?
-Jen <3
Old 12-23-2010, 07:12 AM   #10
It's fairly easy. On your 08 it would require adding the pin to the ECM connector, running the wire through the passenger side firewall grommet and under the dash, across to the steering column, adding the two pins to the connector on the column, removing the airbag, drilling the 1" hole for the stalk in the lower steering wheel cover, mounting the stalk, and moving the horn wire from the existing connector to the stalk's connector.
No one has written up a soup to nuts DIY on doing an OEM stalk on an 07 or older, but all of the pieces mentioned above are detailed in the DIYs linked to in this thread:
http://www.yarisworld.com/forums/showthread.php?t=25515
Old 01-03-2011, 01:17 PM   #11
timmay
Drives: stripped sedan
With all of Scott's posts and fast shipping, I will have CC before my payment books arrive. He is a real stand-up guy, thanks.
timmay is offline   Reply With Quote
Old 02-07-2011, 03:55 PM   #12
cool_beans00
Drives: 2004 Corolla
Still available?
I have an auto 2010 3dr.
From what I can tell, all i need is the stalk, the y-cable, and screws.
cool_beans00 is offline   Reply With Quote
Old 02-07-2011, 05:35 PM   #13
Originally Posted by cool_beans00 View Post
Still available?
That is correct (and I do still have a couple).
Old 02-07-2011, 06:10 PM   #14
matthewai
matthewai's Avatar
Drives: it is kinda stock
so these would just be plug and play basically?
Old 02-07-2011, 09:51 PM   #15
Correct. On 09+ Liftbacks and 2010+ Sedans all of the wiring is in place.
Old 02-07-2011, 10:02 PM   #16
matthewai
matthewai's Avatar
hmm this is tempting and im in ny ill pm if need be
Old 02-10-2011, 11:48 AM   #17
alamocoastie
Drives: 2008 Red LB
Hey scott, want one. Let me know. I need the full set up as I have a 2008 hatch. I can paypal you the money, just need to know where to send it.
alamocoastie is offline   Reply With Quote
Old 02-10-2011, 12:57 PM   #18
SAV912
Pirate Yaaaaris
SAV912's Avatar
So I'm assuming the OEM stalk + wire + ECM wire from the other thread = $50 shipped?
The girl in this tandem wants cruise in her Yaris badly. Esp after a stiff speeding ticket a few weeks ago. Her car is an '08 LB Automatic if that helps. I put it in my '09 LB MT quite easily myself, but hers sounds like a more daunting task.
Please let me know Scott if you still have enough available and if so, I can Paypal you tonight.
-SAV
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
