![]() ![]() ![]() Drives: 09 Yaris 3dr HB, BRZ Join Date: Mar 2011
Brake Upgrades
With thoughts to run the Yaris in lapping days, what are the suggested brake upgrades for the car? (without going to a big brake kit)
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
You don't need anything more than better pads.
Mr. 155 and climbing
I can second that from what I have seen and experienced too. Going crossdrilled, etc on the rotors doesn't really gain you anything and unless mistaken actually will just cause your pads to wear out quicker even if you go with a higher end composition on the pads. xnamerxx is someone you can easily trust on perspective for it too.
![]() Drives: '08 Yaris Join Date: Apr 2014
I'm on OEM brakes, the best upgrade to my brakes was my suspension and tires. The car will throw you through the windshield it stops so quick. I would imagine changing to a pad designed for track (hawk, etc...) would be beneficial in withstanding excessive heat.
Thanks, any thoughts on braided ss brake lines?
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
They provide a slightly better pedal feel, but wont do anything to help reduce brake fade or improve stopping power - the pads, ABS, and your tires are typically the limiting factors when it comes to stopping. They are a nice add on after you have upgraded your pads, just for piece of mind. Go with a set that have a coating over the SS, it helps prevent road grime and grit from penetrating the braiding and damaging the core.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Sports Pads and possibly high temp fluid.
When I ran my xB once on completely stock brakes and it did well. I had to replace the pads shortly afterwards tho! My tercel track day car has been thru several evolutions of brake upgrades as I have gotten faster. Currently have Mazda protege rotors, corolla calipers with Porterfield race pads, super blue fluid, and brake ducting. About to take the plunge into Wilwood land soon...
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
What is the 60-0 stopping distance with your current setup? How much distance are you looking to shave off that number?
Sorry for my newbness...
Anyone able to suggest a brand/model of brake pads and brake fluid I should look for (hopefully something fairly common I have a little over a week to get what I need) Think the oem pads are pretty well worn so want to gettem swapped in time. The event is May 24. How do the oem rotors hold up for events? Hear of some cars that can chew up a set of rotors with a single track day.. |
0-60 in slow
Seeing its a street car Hawk HPS should be fine.
#11 | |
Ford or ATE fluid is very good for occasional track use. I can run for more than a year on a set of rotors and pads. I have used OE rotors, Centric and whatever Pep-Boys has in stock, no noticeably difference in life.
Thanks guys! got all I need to know now I think...
1st ever track day, pretty excited! I've got thousands of virtual laps in... none of the real thing tho.. Hoping this one goes well and will lead to yet another expensive hobby
Heading to Cayuga or Mosport?
#14 |
#15 |
Obsessed with 1.5L
This. I was very happy with these when I was starting out.
Really good street performance and characteristics while still handling track heat. I had 2 weekends and 20k~ on them before I changed my set up and they still had 1/2 their life left.
#16 |
Got the pads ordered, looked up a diy on pad replacement, looks like it will only take an hour to do both sides. Now to see if I can find a pressure bleeder anywhere local in time.
#17 |
![]() ![]() Drives: 2007 yaris HB Join Date: May 2013
Um you shouldn't need to bleed your brakes for just the pads unless you are being proactive and flushing the system.
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| Brake upgrades for my SCION tC | cali yaris | Off-topic / Other Cars / Everything else Discussions | 8 | 07-11-2009 02:23 AM |
| Brake upgrades | majorposer | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 27 | 06-06-2007 03:43 AM |
| Brake Upgrades for Yaris Hatch! | ItalianYaris | Performance Modifications | 33 | 05-09-2007 02:29 AM |
