Old 05-19-2014, 12:42 PM   #1
The 4x108 means you would need hub adapters to use them. This would add positive offset and the fact that the rims are already "high" positive offset means that they would stick out as is, let alone with a hub adapter in between.
Old 05-19-2014, 02:10 PM   #2
Yaristeve
Drives: 3-door hatch
Adding a spacer would reduce the postive offset.
Old 05-19-2014, 02:25 PM   #3
Some day I will get that correct off the top of my head. So, to correct my statement to the OP, the "high" offset wheels would potentially be tucked in too far (depending on what "high" equals). In that case the hub adapters could be chosen thickness wise to offset that extra tuck and bring the wheels out to the correct spacing for the car.
Old 05-19-2014, 04:31 PM   #4
Yaristeve
I understand; you sound like you're an old timer, like me.
The current, accepted sign convention (more negative moves mounting face inward) is illogical to me too. In the old days, a more positive offset made the wheel track more wide, ie.: +offset = +track.
Now it's more negative offset makes the track more wied. Huh?
Old 05-19-2014, 10:19 PM   #5
nortonfb
Drives: 2007
I think I have it now.
Think I'll just wait for some thing else.
Steve
nortonfb is offline   Reply With Quote
Replacement Radio + Steering Wheel Control Questions dinop In Car Entertainment + Electronics (audio / video / alarm) 0 07-07-2013 01:31 PM
Some wheel and tire questions Liu997 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-14-2009 10:33 PM
Wheel offset questions.. Jerkratt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 11-04-2008 01:32 AM
