![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Wheel Questions
I was offered a set of Primax 772 in 16".
Which has a bolt pattern of 4 lug 4.25 inch 108mm High Positive Offset. The offset I really don't understand. What would I need to use these? Is it worth the effort? Thanks, Steve |
The 4x108 means you would need hub adapters to use them. This would add positive offset and the fact that the rims are already "high" positive offset means that they would stick out as is, let alone with a hub adapter in between.
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
Some day I will get that correct off the top of my head. So, to correct my statement to the OP, the "high" offset wheels would potentially be tucked in too far (depending on what "high" equals). In that case the hub adapters could be chosen thickness wise to offset that extra tuck and bring the wheels out to the correct spacing for the car.
I understand; you sound like you're an old timer, like me.
The current, accepted sign convention (more negative moves mounting face inward) is illogical to me too. In the old days, a more positive offset made the wheel track more wide, ie.: +offset = +track. Now it's more negative offset makes the track more wied. Huh? |
I think I have it now.
Think I'll just wait for some thing else. Steve |
Only Happy When it Rains
yea, there are tons of wheels from miatas and civics that fit our cars, no need to get ones that require adapters.
Colin Chapman disciple |
Mazda2 is direct fit
Sent from my XT1032 |
| Replacement Radio + Steering Wheel Control Questions | dinop | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 07-07-2013 01:31 PM |
| Some wheel and tire questions | Liu997 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 08-14-2009 10:33 PM |
| Wheel offset questions.. | Jerkratt | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 11-04-2008 01:32 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
