Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
Thanks for the massive, jagged pill of reality, Crank. Perhaps I should enjoy my sedan while it's still tame and economical, and then save up for triple my budget on performance parts.
Out of curiosity, what do you mean by setting preloads, on transmission? |
#2 | |
2ZR swap. DO IT! Ask how!
The tapered roller bearings on the differential need to be "squished" a little bit to keep them from banging around under load. Too tight = premature wear from friction, too loose = premature wear from rattling/impacting. You check the preload by rotating the differential and measuring the torque required to start it moving. For an open diff, you can use a fork-like extension to grab the spider pinion. For almost all LSDs, you need to either have a chopped off drive shaft or install the pinion shaft with the diff and measure the torque on it. I'll see if I can find a few DIY threads with better explanations/pics of the process. |
#3 | |
Minimalist
| TRD limited slip: part number? | cali yaris | Performance Modifications | 9 | 08-13-2009 01:29 AM |
| Limited Slip | regal | Performance Modifications | 13 | 03-20-2009 09:16 PM |
