#1 | |
2ZR swap. DO IT! Ask how!
The tapered roller bearings on the differential need to be "squished" a little bit to keep them from banging around under load. Too tight = premature wear from friction, too loose = premature wear from rattling/impacting. You check the preload by rotating the differential and measuring the torque required to start it moving. For an open diff, you can use a fork-like extension to grab the spider pinion. For almost all LSDs, you need to either have a chopped off drive shaft or install the pinion shaft with the diff and measure the torque on it. I'll see if I can find a few DIY threads with better explanations/pics of the process. |
#2 | |
Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
| TRD limited slip: part number? | cali yaris | Performance Modifications | 9 | 08-13-2009 01:29 AM |
| Limited Slip | regal | Performance Modifications | 13 | 03-20-2009 09:16 PM |
