Old 07-30-2014, 09:22 PM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
I was able to install the spacer and keep the heat shield on the AFE intake.
Did an initial test 6 mile test run city/hwy after ECU reset just to make sure car runs fine.
1. Idle warmed up RPM is lowered ~25rpm from 620 to 595.
2. Blipping the throttle is sensitive, like having the throttle controller on.
3. Letting the engine lug the car forward is much stronger. Sure the car is shaking but works stronger on my slight inclined driveway.
4. Although idle RPM is lowered, fuel consumption/hour hasn't changed, still 0.125/HR
Manual Transmission
Related Mods: AFE Intake, DC Sports axle back
Check out my Build thread:
Old 07-31-2014, 11:46 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I call that the "tractor effect". If you've ever driven a tractor, the engine does exactly the same thing... the high torque low rpm engines vibrate harmonically as they pull because the time between each power stroke is so long. We have a steep driveway that I measured with an inclinometer at 10%. I have fun going up it in my truck at below idle 500rpm. It just vibrates right up the hill like a tractor without lugging or bucking.
This is one of the strange attributes of the intake manifold spacer that doesn't show up on the dyno runs because it's "below the radar".
Off idle partial throttle performance is superb. If you have a manual transmission there's less clutch slipping needed just to get the car moving.
Greg
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
FS : GT2560R Turbo + Manifold Parmas Items for Sale by private party 0 08-24-2012 08:35 AM
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
