Old 07-31-2014, 09:15 AM   #1
WildChild
The 35 could be due to foreign matter on the tip of the sensor or on the ring that the sensor reads. The rust visible through the hole could mean that the ring is coated.
The ring, by the way, is part of the end of the front axle.
By front axle, do you mean the end of the CV axle/driveshaft, or the hub?
WildChild is offline   Reply With Quote
Old 07-31-2014, 10:50 AM   #2
Yes - The end of the CV axle/driveshaft, just before where the spline enters the hub.
Old 08-01-2014, 06:55 PM   #3
WildChild
The problem is finally fixed. There was so much rust on top of the sensor hole and within the hole that I'm pretty sure that the sensor shifted. It was impossible to put it back in place correctly.
I sanded all the rust on top of and in the hole, removed a few rust flakes near where the sensor tip gets, put some grease on top of the hole and on the base of the sensor to avoid water getting in and I put it back completely in. After clearing the code and driving many KMs, the light didn't come back.
DVD/Navagation System Receiver - Parking Brake Wire??? bteygabroat In Car Entertainment + Electronics (audio / video / alarm) 9 01-19-2019 12:53 AM
can't get brake lights to light gotno DIY / Maintenance / Service 2 02-23-2013 08:07 PM
Light Rust or Grime on Brake Pads ? YodaBird DIY / Maintenance / Service 15 10-22-2012 09:52 AM
Parking Brake Shoe Adjustment bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-14-2009 02:26 PM
