Old 07-30-2014, 08:23 PM   #9
Originally Posted by WildChild View Post
I just removed the sensor to take a look at it. The sensor itself was covered with drips of rust. Looking inside the hole, there was also a lot of rust. Could it be a cause for "foreign material on sensor"? Is this sensor supposed to be completely sealed to protect the inside? I'm not sure if I saw rust in there when I removed the sensor on the other side a few weeks ago.
After cleaning the sensor and putting it back, clearing the code, the ABS light came back within 100 meters, again with a 35 code.
I will check the sensor for continuity later tonight or tomorrow. If the sensor itself looks good and there isn't supposed to be rust there, what parts could need replacement?
Thank you!
The 35 could be due to foreign matter on the tip of the sensor or on the ring that the sensor reads. The rust visible through the hole could mean that the ring is coated.
The ring, by the way, is part of the end of the front axle.
DVD/Navagation System Receiver - Parking Brake Wire??? bteygabroat In Car Entertainment + Electronics (audio / video / alarm) 9 01-19-2019 12:53 AM
can't get brake lights to light gotno DIY / Maintenance / Service 2 02-23-2013 08:07 PM
Light Rust or Grime on Brake Pads ? YodaBird DIY / Maintenance / Service 15 10-22-2012 09:52 AM
Parking Brake Shoe Adjustment bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-14-2009 02:26 PM
