Old 09-08-2014, 05:37 AM   #6
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
I don't think it is the bearing. because usually if its bearing that noise should get worse as speed increases.
I looked at the Yaris repair guide for handbrake adjustment, it shows how to adjust for drum brakes but not disk.
I think all that needs done is to adjust the handbrake setting to make sure that the pads aren't touching the discs so tightly on handbrake released . Does anyone know how to do this?
JudgeM is offline   Reply With Quote
Tags
brake, noise
Pass Rear Wheel Bearing regal DIY / Maintenance / Service 4 12-23-2014 05:01 PM
How to remove rear wheel hub? Gpav6 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 08-01-2014 10:38 AM
Can I fit this 9" wide wheel in the rear? PETERPOOP Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 09-04-2009 05:50 PM
