Old 09-06-2014, 12:45 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Hum noise sounds like bearing going if not and u find that bearings are fine and u have disk rear , make sure the pin sliders move free also pads ..clean the are lube/grease sliders all should move free same with piston .
As for drums , clean and adjust remove any rust of drum and so on .
sent from my S4 on Mars
Tags
brake, noise
Pass Rear Wheel Bearing regal DIY / Maintenance / Service 4 12-23-2014 05:01 PM
How to remove rear wheel hub? Gpav6 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 08-01-2014 10:38 AM
Can I fit this 9" wide wheel in the rear? PETERPOOP Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 09-04-2009 05:50 PM
