#1 |
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
Pass Rear Wheel Bearing
Anyone know where I could find a passenger rear wheel bearing for a 2009 Toyota Yaris? I'm coming up empter.
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Autoparts store would either have one or be able to order one. if not the dealer would get one for you.
Have Yaris will travel.. |
#3 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
you want just a wheel bearing? replacing the entire hub would be easier. eBay has them, i was looking at 50 bucks for one with ABS.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#4 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
RockAuto.com may help.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#5 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
This was posted in the wrong section, moved it. Please remember to post your threads in the correct section.
| Yaris 2007 sedan (auto) Transmission fluid change and rear wheel noise | DevilzMafia | DIY / Maintenance / Service | 8 | 12-24-2012 08:05 AM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
| Installing Rear Wheel Bearing Hub | brad4ds | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 07-22-2011 06:34 PM |
| Front Wheel Bearing Failure | craigq | DIY / Maintenance / Service | 4 | 08-17-2007 07:26 AM |
